SD MUKARRAM ALI HUSSAINI
I want to make a microphone circuit which is able to transduce audio signal into electrical signal.
ok my last query:in my attached document, by varying R1,R2 can i obtain required output???in given circuit graph,it is giving high and almost same gain between 100Hz-50KHz...(human hearing range;20 Hz-20KHz)
The output of a microphone is an electrical signal when it hears sounds.I want to make a microphone circuit which is able to transduce audio signal into electrical signal.
Varying them will change the gain - but it really depends what your 'required output' is.
Why do you want 5-6 volts? What current? What is it for?
Can u pls tell me in details what u want to say???The battery needs a DC current to charge it.
But the output of the mic preamp is an AC signal with its current too low.
Instead of rectifying and boosting the output current of the mic preamp then simply use the preamp's power supply to charge the other battery.
after doing some improvement in my attached circuit...is it possible what i want to do????if yes pls suggest modifications...
i want 5-6 dc volt to charge battery....is it possible to obtain by varying R1 and R2 in my attachment???
