lowering voltage and current....
ThE_sPaCeCoWbOy
I have came across a Idea that I want to pursue....
Basically what I want to do is take a set of car batteries...lets say 3....I want to hook 2 of them together (24V) and use the third one to compare....now I know if I hook this up to a voltage comparator, its going to burn it up...my question, is how do I lower the voltage and current of these car batteries so I can use IC, transistors, etc...?
Thanks,
space
ThE_sPaCeCoWbOy
I'm wanting to compare the 2 batteries that I hook up together to the one battery left....
When the two batteries aren't putting out what the 3rd one is, then the system shuts off....
I'm just looking for a way to lower the voltage and current of a car battery so I can use it in a circuit...
space
Roff
I hate to sound like a nag, but why are you wanting to do this? What is your application? I'm asking because the solution is frequently simpler if we are not constrained by your preconceived notions of how you have to solve the problem. Are you drawing power from all the batteries, or is the 12 volt one simply for use as a reference?
Optikon
Thanks,
space
I agree with Ron, you say it will burn up... that has yet to be seen! :)
Did you know that you can find ICs and certainly transistors that can work with 24V? It would be very helpful if you could explain further what you are trying to do. But if nothing else, you can always use a resistive divider to reduce voltage and limit current on the front end of your comparing circuits.
panic mode
Do yourself a favour and rip the PSU from old PC (they are usually free and don't need load to start). You will get plenty of power and usable (commin) voltages. Actually power supply is good start project. Before you start making gadgets etc. build some bench equipment that will help you with your work. Just to name few: PSU, Logic probe, Function generator, Signal tracer, Capacitance meter (if you don't have it on your multimeter) etc.
mattg2k4
ATX power supplies from computers usually require a load on the 5v line to function properly. Some power supplies even have the minimum load listed next to the max load of each rail, but a 10ohm 10 watt resistor on the 5v line to ground should be fine.
ThE_sPaCeCoWbOy
I'm sure there are transistors that can handle 24V...I'm more worried about the current that is going to be going through it....are there transistors that can handle this much current?
space
Nigel Goodwin
Super Moderator
Most Helpful Member
space
I agree with everyone else, you need to say what you are trying to do, the current handling requirements depend entirely on the load - which you've never mentioned. Transistors are available which handle substantial currents, and you can always use more than one - but you would tend to need large heatsinks.
Noggin
You know, I always wanted to build a variable power supply (would like to make it digitally controlled too) for myself so that I would have one available. I never thought 'bout makin a func. gen or cap meter.... those would be nice to have too :) Thanks!
ThE_sPaCeCoWbOy
I did mention what I wanted to do...I'm wanting to compare the 2 batteries that I hook up together to the one battery left....
space
Roff
The reason I'm asking is we can use the 12 volt battery as a power supply for the comparator and the switch if that is allowable.
ThE_sPaCeCoWbOy
oppps...didnt see that last part of your post Ron...
No....I want to still use 3 car batteries...I want to be able to alternate them....like battery 1+2 compared with battery 3, then when that is down, battery 1+3 compared with 2, etc....
hope this helps
Travis
Roff
hope this helps
Travis
Travis, I don't mean to be nosy, but whut the heck are you powering with these batteries? And do you really plan to electronically switch to the different combinations? What do you have that will run over the range of 24 volts all the way down to 12 volts?
adam12
if i understand the question correctly, you want to lower the voltage of the two car batteries that are connected in series? this would defeat the purpose of connecting them in series because series gives you the higher voltage level. if you want a voltage that is between 12 and 24, or lower than 12, you can make a simple voltage divider circuit using as little as 2 resistors (want to use resistors that can handle high power). just connect the resistors in series with the battery and the required voltage is seen across one resistor (i can give some resistor calculations if this is what you are talking about)
as for the current, that is totally dependent on the load you are driving. if you want to lower the current that is drawn from the battery, add another resistor to your load. this will lower the current as needed
i don't know if this is what you mean or not
just some ideas
adam
Russlk
I hate to sound like a curmudgen, but I don't believe that someone who doesn't know enuf to describe the problem will be able to use the advice offered. It appears that it is not known what constituts a dead battery, or what is to be done about it. We are wasting our time.
ThE_sPaCeCoWbOy
If you feel that you are wasting your time then why bother posting a reply? This is a information board that those who are willing to offer advice can do so at there own free will...You speak for yourself, not others....if you wish to discuss this matter more, feel free to pm me...Have a nice day :D
Like I said I know what I want to do with it....all I want to do is lower the current of the car battery so that I can use it on a VC without burning it out....
again those who offered advice and ideas...thanks...keep them coming
space
Roff
space
As I said in my reply to your PM, and I repeat here for other novices, comparators such as LM393, and many transistors, can handle 24 volts with no problem.
Current is not an issue. You don't have to "lower" it. Power sources supply only as much current as a load demands. If you have a circuit that draws 10ma from 8 AAA cells in series, it will also draw 10ma if you connect it to a car battery.
a_drunken_dwarf
batteries, wall outlets, everything will only supply as much current as is 'drawn' by the circuit. So if you just put a straight wire between power and ground, sure there will be a crap load of current because V=IR: I=V/R, I=24V/.000001.
But if you put resistors in your circuit, you can geatly increase the resistance. This will decrease the amount of current going though it. Just use V=IR to find out how much current will be going through your circuitry. R= the total resistance of your whole circuit. V=24 volts (assuming power is comming from the two batteries hooked together). then solve for I=V/R.
