ADWSystems
I am looking for some options for the mechanical side of automating a duct work blast gate. This is one of the actual blast gates, typically used in woodworking but also elsewhere. The gate slides approximately 4" for the one pictured, but I'd like to keep the design scalable to do 5" and 6" as well.
Blast Gate Photo
I have much of the control and interface designed, but I'm looking for solutions for the mechanical side (the simpler the better)
So far I have come up with the following ideas:
1. Pneumatic cylinder with a matching throw (4, 5, or 6 inches)
2. Solenoid, pneumatic cylinder, or automotive door lock actuator. These all have short throws, but a lever arm the proper length throw could be achieved.
3. Whatever you guys come up with.
I was watching TV and saw a train drive wheel and got another idea. A motor with an arm the correct length and attach it to the lip (facing down and away in the picture). The end attached to the gate would be able slide because arm would swing an arc (not travel linear like the gate will). I'm figuring on a DC motor (because it would have to be reversible) and rotating the motor only 90 degrees. I'm stuck on figuring out how to limit the motor's travel and when to stop the motor. Any ideas? All suggestions are welcome.
P.S. Please keep in mind I'm trying to keep this cheap and use parts that are readily accessible.
Blast Gate Photo
