Load Regulation Equation
mananshah93
I am deriving load regulation for 7.5V 2Amp. linear power supply, but I am confused regarding the equation of percentage load regulation.
which of 3 is correct?
1....Load Reg = {(Vn - Vf) / Vf} x 100%
where Load Reg = load regulation;
Vn = no-load output voltage;
Vf = full-load output voltage
OR
2....Load Reg. = V full load -V Minimum Load
V nominal load
Where:
FullLoad is the load that draws the greatest current (is the lowest specified load resistance - never short circuit)
MinimumLoad is the load that draws the least current (is the highest specified load resistance - possibly open circuit for some types of linear supplies, usually limited by pass transistor minimum bias levels)
NominalLoad is the typical specified operating load
OR
3.....Load Reg = {(Vn - Vf) / Vn} x 100%
#1 is correct.
What you are measuring is the % change in voltage from when the supply is unloaded to fully loaded, the smaller the figure the better.
Thanks, I have designed 7.5V 2 Amp. power supply using LM338, 230 to 12V 3Amp. Transformer, Bridge Rectifier having 1.1V Forward drop per bridge and filter capacitor around 20000MF.
I am having load regulation of around 1.06 percentage, but I read that linear power supply can give regulation of 0.01 %, how to achieve this?
Sorry buy I think you've wasted your time because an audio amplifier doesn't need a regulated supply.
Sorry, I thought it was for an audio amplfier.
What do you need to power with this power supply?
It might not need a regulated supply, a 6V transformer with a bridge rectifier and 22,000µF capacitor might do.
The datasheet for the LM338 specifies a worst case of 0.6%, however it has a thermal stability of 1% meaning the output voltage can drift by 1% over the temperature range. Given the heating of the die, the regulation and the resistance of the wires, it woudln't surprise me if this could amount to 1.06%.
How thick are the wires?
How good is the heat sink?
https://www.electro-tech-online.com/custompdfs/2009/08/LM138PDF.pdf
