let's see if i'm getting this right.
When you go to Radio Shack, ask for part number 276-1617. This is a package of 15 general purpose NPN transistors similar to the popular 2N2222 or others called for in most small-signal circuits.
Regards,
AllVol
i don't know why all my pics come oout fuzzy today but thats the schematic of what i have in the pic. if i switch the collector and emitter around i get pretty much the same results. and as long as theres resistance on the base it works if not nothing happens!!
i got part number pn2907-type pnp trans
specs as on box. (max)
VCEO= 40v
vcbo= 60v
vebo=5v
IC=.8A
PD= 625mW
fT= 200mhz
its all they had in stock for pnp's!!
hey, buickskill
When you get your transistors from RS (see above for part #) go by the attached schematic.
NOTE: If you are using 32 vdc supply, change the resistor between V+ and the LED to one of about 1500 ohms (brown-green-red striped) and about 15,000 (brown-green-orange) on the base. You would really be better off to pick up Radio Shack part #270-412, a three AAA battery holder ($1.69). This will give you 4.5 volts, enough for most experimental projects.
okey dokey. i will check and see when they have those transistors in because the only one they had was cat number 276-2023. so i got it. i'm gonna up and mess with that a little.
Okay, buickskill
That transistor is alright, but you will, as everyone has said, need to reverse the polarity for my diagram.... put V+ (positive) to the emitter, and the collector and base to negative. I still think you need around 5 to 9 volts, however, if no other reason than to understand and comply with most of the circuits floating around.
You can use the PNP transistor, ie. the TIP42C with a positive supply.
I'll post a circuit later.
AllVol said:
hey, buickskill
The 1k in the base is an over kill.
For Red LED I estimate the collector current will be about 13.6 mA. So you need about 1.36 mA of base current.
Thus for a 5V supply, a 3k3 resistor would suffice.
It is hard to read the circuit as it is out of focus. Does your camera have macro function?
As far as I can see, the transistor appears to be a TIP42C. If so, then you're using it the wrong way around.
I'll post a circuit shortly.
Here it is with a 12V supply for a Red LED.
Hi Len
I used 5 volts for supply in my schematic to your 12, thus the difference. I also adjusted for his 32 volts, or at least I think that's what he shows in his fuzzy picture.
Regards,
AllVol
I think RadioShack gets "seconds" that don't work. Noobies connect them upside down and backwards and think their circuit is wrong.
AllVol said:
Hi Len
Regards,
AllVol
G'day AllVol,
I could not make much out of the picture, so I drew my own.
I used 12 V as he wants to eventually run it on 12.
cheers,
i just got back NPN 2n3904 trans they didn't have the one mentioned earlier so i got this one!!
That transistor should be adequate for your experimenting.
But it has a maximum collector current of 200 mA and a max power dissipation of 625 mW.
So if you are only using it as a saturated switch, then it will be safe up to 200 mA.
Yes, and I suspect that some don't bother to come back and ask for more help, ie. as you said, assume the circuit is wrong.
Personally, I use Radio Shack components quite often. I have five stores in my area, so usually parts are available when I want them. I can't say I've ever experienced "seconds" or non-working parts, although many transistors will have manufacturer markings. It is important to keep components properly marked and/or separated. Sure, the per component cost seems high, but if one considers the shipping and handling costs, plus usual minimum orders plus the delay in receipt, a few extra cents do not mean much. I do my shopping ahead of time by going to www.radioshack.com , selecting components I want at the best price. I can also make sure which store has the part.
Don't give Radio Shack a bad rep, but they do need to carry more items.
Defensively,
AllVol
