LCD SPI projects.
Cleared all the ILI9225 out of the Arduino IDE, there seems to be a problem with the original ILE9225 download from git hub.????
Downloaded the Arduino version, at first it was very poor quality pixel output.
Changed program from hardware SPI, to software option, now running OK.
E
EDIT:
Now have it running under hardware SPI, the 9225 is very edge sensitive.
Added a 2k pull up to RS and about 3pF to RST it now gives a clean fast operation.[ all 3 modules]
The software SPI is too slow IMO.
Will experiment with a intermediate buffer IC.
Here is a schematic of the latest 18LF4520 TEST PCB.
As usual check for faults, please.
EDIT: I've edited the 5110 out of the title.
EDIT: I can change the 5110 to the present module, if wanted.
C.
hi, Nigel Goodwin
After a quite a few hours, with no success, trying to use Oshonsoft basic to drive the Hiletgo 2.2inch SPI TFT LCD, I decide to retry the 3 off, Arduino UNO with the 3 off, TFT LCD modules.
All the SPI and control signals were monitored on a scope and appeared OK
When using the Arduino program hardware version of the SPI, the LCD's would work intermittently, with very poor quality or sometimes not at all, when the module was subject to even a small rise in ambient temperature, but worked OK with the software SPI, but slooow.
Do you have any information regarding the work you have done when using these TFT's, with hardware/software SPI.?
I am wondering as the price per module was lower than expected, that I have bought some production rejects.
Eric
Sounds like the clock polarity is wrong... These module clock on the rising edge The ILI9225 has a High polarity and the ILI9341 has a Low polarity... The Hiletgo 2.2inch can have the latter chip in!!
hi, Nigel Goodwin
Hi Eric,
Mine haven't come yet, although I have received a couple of similar sized 240x320 modules I ordered at the same time, these use the ILI9341 and I simply plugged them in, in place of the larger ones I already have, and they worked with no changes.
As soon as they turn up I'll give them a try, although I'll obviously have to port the code to PIC to test them with a PIC.
OK, mine arrived today - just tried them both (I ordered two), first with software SPI - so the module plugs directly in the Arduino, but you have to alter the pins used in the driver demo. I then removed the display and wired it to the hardware SPI, both worked fine again?.
Obviously if it works with software SPI, it 'should' work with hardware - unless it's set to the wrong mode, or it's running too fast.
I'll get a board made for a PIC, and port the library for it.
Works fine on my PIC24F here as well, on both software and hardware SPI - I'm feeding it with 3.3V supply and signals, and it's fine at that.
If anyone is interested in some even cheaper LCD's?, I've ordered a couple of these:
https://www.aliexpress.com/item/2-0...ouch-Pen-R179T-Drop-Shipping/32780151979.html
Slightly smaller at 2 inch, and not 5V tolerant, but does come with a touch screen as well - and at a silly price. They also use the ST7775, which I prefer to the ILI9225 - which doesn't seem to provide screen rotation, and has to be done rather crudely.
hi Nigel,
Book marked your ali link, I will order a couple of modules.
The 3, ili9225 2.2" TFT LCD modules I have, are still giving intermittent operation.
Checked the onboard 3Vreg its OK, the onboard HC245 level shifter should be OK for 5V signal to 3V conversion input to the 9225 IC.
The sort of mis-operation I get with S/W and H/W SPI are:
Works OK 'sometimes' when powered On, runs the Arduino UNO demo OK, other times no operation or corrupted display.
Pinching a connecting wire between finger and thumb can cause display corruption.
Connecting wires from UNO to LCD are approx 3" long.
Having the module powered from the USB or a external 9Vdc PSU or both, gives the same intermittent operation.
Tried 3 Arduino UNO's , these UNO's work OK on other SPI projects.
Noticed also that the LED back lights do not work.?
Becoming convinced that I have three duff LCD modules.:banghead:
Eric
Seeing that you used 3.3v, I decided to try resistive dividers 2k2/3k3 between the 5v powered UNO and 5v powered TFT, on all 5 signal lines.
All three LCD modules now work OK, with HW and SW SPI.
It looks as though the onboard HC245 level shifters are not working as expected, perhaps getting 'punch thru' of the 5v signal levels.
Now its back to the 18F4520, added the resistive dividers to the development board.
Eric
Now have the 9225 LCD module working with Oshonsoft Basic, programmed into a 18F4520 PIC.
Both the PIC and LCD are powered by 5v, series 2k2 resistors in series with the 5 signal lines, are required for stable operation of the LCD.
The screen fill speed with colours is comparable with the Arduino in software SPI mode.
The Oshonsoft SPI, as most users know, is software based, which is a pain.
Next step is to tidy up the graphics then write text to the LCD.
E
Do you want me to write a hardware version??? It'll be quite simple...
If you send me your init code and the graphics write it'll speed things up..
hi Ian,
Thanks for the kind offer, I have more work to do on the 9225 Basic program development, ie the text routines.
I have considered adding a SPI assembler block of code to the the final Basic program, so I may get back to you shortly.
E
Slowing down a little, now in my 86th solar cycle.!!!:woot:
hi Ian,
E
Hi E,
86 and as sharp as ever, well done.
C.
hi C,
In the 86th Solar cycle means I am only 85!, at the end of this annual solar orbit I will be 86.
Eric
I did a tiny hardware SPI function for Oshonsoft... I tested to 2mhz on a 25c320 SPI memory chip!!
If used with your screens, it'll speed things up a tad!!
Here is the code for a pic18f4620 running at 8Mhz internal clock..
Define CONFIG1L = 0x00
Define CONFIG1H = 0x08
Define CONFIG2L = 0x1e
Define CONFIG2H = 0x00
Define CONFIG3L = 0x00
Define CONFIG3H = 0x83
Define CONFIG4L = 0x80
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
Symbol ss = LATC.2
Dim x As Byte
Dim ret As Byte
OSCCON = 0x70
ADCON1 = 0xf
Call spi_init()
TRISA.5 = 0
LATA.5 = 0
WaitMs 10
For x = 0 To 32
 ss = 0
 ret = do_spi_8(6)
 ss = 1
 ss = 0
 ret = do_spi_8(2)
 ret = do_spi_8(0)
 ret = do_spi_8(x)
 ret = do_spi_8(32 - x)
 ss = 1
 WaitMs 10
Next x
LATA.5 = 1
stop: Goto stop
End
Proc spi_init()
 TRISC.5 = 0
 TRISC.2 = 0
 TRISC.4 = 1
 TRISC.3 = 0
 ss = 1
 SSPSTAT = 0
 'SSPSTAT.CKE = 1  'clock edge un remark for trailing edge
 SSPCON1 = 0x20  'full whack... at 8mhz 2mhz operation no SS control
      '00 = fosc/4.. 01 = fosc /16
      '10 = fosc/64.. 11 contolled by timer2.
 'SSPCON1.CKP = 1 'clock polarity unremark for high polarity
End Proc
Function do_spi_8(data As Byte) As Byte
 do_spi_8 = SSPBUF
 SSPBUF = data
 While Not SSPSTAT.BF
 Wend
 WaitUs 10
End Function
hi Ian,
Many thanks for that, have downloaded your program, it compiles OK, has to rem out the ----------------------- spacers.
Trying it it out later.:)
The simple LCD graph functions have been tested, reasonable.
Started on the Basic for the writing text to display, the limitations of the Oshonsoft maths conditional statements means loads of work arounds, calling it a day, start fresh tomorrow.:banghead:
Eric
I am trying to do a linear buffer for oshonsoft.. I want a 1k buffer for screen double buffering..
I only did that because copy and paste didn't!!! It looked awful without....
hi I,
I got some 18F4620 for SD card projects.
E
