LCD interfacing
darsh
I bought an 16x2 lcd - JHD126A but i m having problems interfacing it with Atmega32. i m using it in 4 bit mode. is this and hd47780 are compatible lcd's ? also does the header file lcd.h which comes with winavr adaptable with this lcd? right now i can only see black squares on my first line of lcd screen. is there any code available ot tutorial available so that i can directly implement the functions like "lcdputs()" etc..
thanks
thanks
Have you checked the avrfreaks site.?:)
Do have a 'contrast pot' on the LCD.??
View topic - Help : LCD interfacing with ATmega32 :: AVR Freaks
Connect LCD to Atmega using 3 wires - Scientific, embedded, biomedical, electronics contents.
thanks
Darsh, it is JHD162A.
it is compatible with the standard hd47780 LCD displays. It can be used for 4 bit mode even with ATMega32
please adjust the Contrast pot for a better visibility. the best for this mode appeared to be a voltage of approximately 0.6 to 0.9 V on contrast pin.
please see the link below
https://www.electro-tech-online.com/threads/atmega32-and-hd44780-lcd-driver.85774/
i m using a potentiometer for the contrast pin and the display works well.
but i need it to use in 4bit mode.
