That should work with an LDO regulator.thinking of a voltage regulator? then adjust the pot and hopefully the display will be correct without having to readjust the pot.
Except that only regulates to with 2-3V below the battery voltage,Venerable LM317 in a TO92 case
Have a 2 x 16 LCD and a 10k pot to adjust the LCD with but is there a method to avoid having to readjust when changing batteries?
In which case it's not an Hitachi HD44780 compatible one, which uses an input pin voltage for display contrast, and optionally has LED back lighting, who's brightness you can vary by altering the LED current (usually a resistor feeding it).My old 16x2 LCD has instructions for pixel brightness and background brightness
