LCD Interfacing with K60 micro-controller
brsowmya
Hello ,
I'm new to this forum. I'm using LM16200 lcd interfcing with K60.
I'm able see the signals on data lines operating in 4- bit mode. But if I send wake up command, the response from LCD is "cursor on" . Can anyone suggest me , where the problem i'm facing?
Sowmya
Attached is the datasheet I refer to when using a 2 line 16 digit LCD display. Look at the flow chart on Page 13. You need to insert the delays or it wont work.
  • 2x16_lcd_display.pdf
Yes check your timings, some displays are tolerant but others mess up unless you meet minimum delays.
