Hi
We are developing a 12kW , 48Vout Power supply with 9mF of output capacitance.
It is for a customer load which also has a 72Ah lithium battery connected in parallel with the load. (there is no inrush circuit on the load).
So we designed an inrush limiter to staunch inrush from the customer’s battery into the power supply’s output caps upon connection…however, the customer has requested we remove this, and that we simply make the connection, and tolerate the contact sparking as their battery inrush’s into the power supply output capacitors.
How long do you think the connector will last even if its highly rated up for such treatment?
