Inductance
codan
Hi All,
I need some help with an inductance reading on my Multimeter as i have lost the the instruction manual for it--Duh!!.
I have a coil of wire & when tested on the 2mH setting it reads .289, could someone tell me what measurement this is. Eg is this .289 Henries or ?
Also i need to get this Inductance reading using a coil of 16mm^2 cable, is there a way i can calculate how long the 16mm^2 cable needs to be to get the required Inductance?
I think that means it is .289 millihenrys or 289 uh.
the setting on your meter is a maximum for that setting. when its switched to the 2mH setting, if you try to measure something like a 4mH coil, it will read "overload," "OL," or just a 1 on the left with the rest left blank. The "multiplier" is the "mH" meaning all readings for that setting are in mH. so a reading of .289 means 0.289 mH. if you switch to, say, the 2 H mode (i doubt there is one that high, but just for example...) in the 2H mode, if it read .289, THEN you would read it as 0.289 H (no milli).
agree with the above
L = 2l[2.303 log(4l/d)- 1 + u/4 + (d/2l)]
In this equation, L is the inductance in nH (10-9 henry), l is the length and d is the diameter of the wire/rod (both in cm). µ is the permeability of the material (=1.0, except for iron and other ferromagnetic materials).
I guess you can take u = 1
