Important features to have on 18F4620 Board?
Krumlink
Well right now as far as electronics goes, I have been working on a little 18F4620 control board, and I have figured out what ports will do what:
PORTA Motor Control, LED output for Motor controls
PORTB Sensor Interaction/LED indicators
PORTC Sensor Interface?
PORTD Dunno?
PORTE Use E0,E1 E2 (E3 is reset, want to have that seprate) as LED indicators
Problem is, that I have a lot of pins and ports to work with (take that Basic s*** 2)
So I was wondering what should I do with Port C and Port D? I was thinking of using them and bringing the pins to a LCD board (I understand the basics of LCD's now :)) and I am thinking that would be a good idea.
I have each port brought out to 2x5 headers (awesome idea by 3v0 on his boards) and I could easily change the function if needed. I have a HD74480 LCD so I can easily communicate with it, and I have already programmed a LCD with my uPICFAT to display "WHAT CHU TALKIN BOUT WILLIS" on it. I have also just started with INPUT commands too, and by taking data from an input and displaying it on the LCD (button input).
So what should I do with entire PORTC and PORTD?
www.crosstheroadelectronics.com for the uPICFAT (I got mine for free, the guy who sells them is a mentor on team 217 Thunderchickens who is visiting my HS today :D)
The 2x5 port connector goes back a long way. They may have existed on the targets I used back in the mid 70's.
I think you are on the right track already. I would not try to use up the ports. Keep them available via the 2x5's so you can add functionality as you need it.
EDIT: On could argue that you do not need such a large chip. Given that you do not know what your final robot will look like I like the idea of the extra ports.
I was going to have Ports ABCD on 2x5 headers, and have E0,E1 E2 and E3 (E3 is reset) as dedicated LED's and E3 as a reset. I will then have seperate boards that go from the port I need (say, a PORT D LCD board).
I would definitely fit an LCD as it makes debugging so much easier. Breakpoints and single stepping are great until you get time critical stuff. For the rest of the ports, I agree with 3v0, keep them free until you need them.
What language are you using?
That is the normal character based LCD data sheet. What makes you think it isn't?
I got confused a bit. I think I have a different LCD than that :confused:
There are LCD that have different connectors. Does yours have the 7*2 connector on the left hand side?
Like this,
OK. I have everything all figured out, and I really confused myself. I have the HD44780 LCD and how to interface with it. LOL.
Mine has the 16x1 header. It is a 16x2 LCD, and the uPICFAT does not utilize all 8 data lines, but I will have to use 2 ports to use the LCD (read write) if I wanted to use all 8.
EDIT: I have decided to utilitize all 8 data lines, taking up an entire port. I also have the option to change what module to use on it too. I then need a Read/write control, and a instruction/register select line. :)
But that pretty much requires dedicating pins on the PCB layout that might be needed for some other project.
I'm beginning to think that using a dedicated PIC as an LCD interface which supports SPI, I2C, or Serial connection to a host device might not be a bad idea. Then all you need is 1, 2, or 3 wires from any project board to connect to the LCD (and keypad perhaps?) when you need it.
Mike
<added>
The first general purpose PIC proto' board I designed (2003) had a 28 pin footprint within a 40 pin footprint which allowed me to use either type of chip on the same board. I wish I had had the foresight to install 10 pin dual row connectors for each port (great idea)...
proto-28-40-board-jpg.19671
I am making this on a radioshack perf board, because I wanted to be able to make this somewhat quickly. In the future I can make a PCB if this design works well.
I have come up with a sweet acronym as usual :)
ViPER
Versatile Programmable Experimental Robot
awesome eh?
I made a few LCD adaptor boards. It allows you to connect a 1x14/16 LCD to a standard 2x5 port in the 4 bit mode. No need to dedicate pins to the LCD if it is only used during debug.
lcd2x5-png.19672
lcd2x5sch-png.19673
It is single sided. The red line above R1 is a jumper.
I can post pdf's of the foil or the eagle files if anyone wants them. Not a difficult board to layout.
EDIT: R2_OPT and R3_OPT can be used in place of the 5K pot.
3v0,
Hook the LCD backlight Anode to VCC and put the backlight Cathode on the unused connector pin where I can drive it with a sinking PWM signal and that adapter would be perfect...
I have a similar manufactured adapter but they hard-wired the backlight to power pins (with appropriate dropping resistor) and the R/W pin to ground. It's got two unused pins on the 2x5 connector but I can't cut the backlight and R/W connections because they're buried. Bummer!
Mike
Changed as requested. Also made the board a bit easier to etch and solder. The pdf fils is a foil pattern that can be printed and etched. The zip file contains the Eagle sch and brd files.
1b_sch-png.19676
1b_brd-png.19677
  • LCD_4Bit_16_TO_10_ADAPT_1B.pdf
  • LCD_4Bit_16_TO_10_ADAPT_1B.zip
3v0,
Very nice. "Perfect" does indeed apply. I'll take two (grin).
I meant to edit my post to say it would be nice to have the backlight cathode available on the connector so that I could drive it with PWM or ground it but I couldn't edit my post.
btw, I wouldn't be opposed to a installing a couple jumpers if those small traces between pads is a problem...
Mike
3v0,
Mike
Are you saying you want the anode hard wired to +5 and the cathod to the connector pin. As in I have is bas awakards? If you think I still do not understand mark up the schematic using a paint program.
The lines between traces should not be a problem with a decent setup. The thin lines here are .012 and I have used .001. The .012 is quite dependable but the .001 traces need to be verfied after etching. Most of the time they are good.
1b1_sch-png.19683
Yes, backlight anode to VCC and cathode to the connector. Sorry I didn't notice it in your first updated drawing.
Mike
