Okay, I dug out my copy and posted the page. Check your wiring again. The only thing i can see might be in the upper right corner, where the lines from pin 4 and pin 3 cross... They aren't connected, but putting 12 volt through the output (pin 3) would cause smoke as you described. What voltage relay are you using, coil impedience? Too big could cause some heat.
