I need a switch circuit please
ahonda55
Hi all , i am Ahmed from egypt...
First of all , GREAT work , really great forum.
I have a small project , and i need help from every one who can help me.....
What i need is a switch circuit drives a 12v relay at exactly 3 volts or more.
i mean a small simple circuit that closes the 12v relay when the input signal voltage of the circuit reaches 3 volt and opens the relay again if the signal runs below the 3v , and that circuit operates at 12v.
PLEASE this is my first request in this forum , so Plz help meeeee !!
any circuits , any links , any ideas anything :oops: :oops: :oops:
this as a base circuit should work, you might just need to change a few values of components in there, if you wish to get the 3v/12v exact change
it didnt show my diagram, ill try again
thanx , i had seen the circuit , but i can't understand anything .
The cicuit i need is not to switch between 3v and 12v , it runs on 12v , and the input signal is 3v max. so when the input reaches 3v or more the circuit output closes the relay.
Thank you very much
i must have phrased mine wrong. unless i have missed something drastic in my diagram, i think that is exactly what youre looking for
The cct switch on about 3.2-3.4V input. If You need higher precision, use a comparator.
