hyperterm to uart(rx)
butters
#pragma interrupt rx_handler
void rx_handler (void)
  unsigned char c;
  /* Get the character received from the USART */
  c = ReadUSART();
  if (IPR1bits.RCIP)
      /* Display value received on LEDs */
      PORTB = c;
      //putsUSART (data[c]);// writes string of character from data[c]
  else
      putsUSART (data[11]);
      PORTB = c;
    /* Clear the interrupt flag */
    PIR1bits.RCIF = 0;
hi all is there any specific setting that i need to do so that my values from hyperterm would be display in int c as it a ReadUSART() which captures from it...?
I don't understand your question. I also don't understand why you are testing the interrupt priority bit in the interrupt.
If you post some complete code with an explanation of what you think it should do and what it actually does then you are far more likely to get an answer.
void main (void)
TRISC = 0b00100000; //set RC7 and RC5 as output and RC6 as input
ADCON1 = 0x0F;
  OpenUSART (USART_TX_INT_OFF &
             USART_RX_INT_ON &
             USART_ASYNCH_MODE &
             USART_EIGHT_BIT &
             USART_CONT_RX &
             USART_BRGH_HIGH, 25);
//transmit
//set RC5 to 1 to enable tx transmission
PORTCbits.RC5 = 1;
	//value sent
	putcUSART(0x66);
PORTCbits.RC5 = 0;
/* Enable interrupt priority */
 RCONbits.IPEN = 1;
  /* Make receive interrupt high priority */
  IPR1bits.RCIP = 1;
  /* Enable all high priority interrupts */
  INTCONbits.GIEH = 1;
  /* Loop forever */
  while (1);
here is a main part of the code.. the usart is suppose to transmit a hex value of 66 to the hyperterminal. the hex value will display as "f" in terms of ascii format..while it is transmitting, an interrupt of receiving from hyperterminal occurs.. here is the interrupt routine...
//location of the ISR
#pragma code rx_interrupt = 0x8
void rx_int (void)
  _asm goto rx_handler _endasm
#pragma code  //return to default code section
  unsigned char c;
  c = ReadUSART();
  if (IPR1bits.RCIP)
      PORTB = c;
  else
      PORTB = c;
    PIR1bits.RCIF = 0;
this is the interrupt service routine which im working on.
im suppose to make char c capture values from the hyperterm through ReadUSART()..
upon successful receiving, i need to do a watch window so that the values from the hyperterminal reflect on it...
but theres isnt any values coming out from the char c in watch window...
i hope this clears everything...
thanks..
What is the line,
if (IPR1bits.RCIP)
supposed to do?
And you have still posted part code. Maybe you set port B to output somewhere maybe not. Without code that compiles, everyone has to guess what your code does and so the chances of anyone working out the error are practically nil.
What is the line,
if (IPR1bits.RCIP)
supposed to do?
im stuck until the if (IPR1bits.RCIP) part.. i dont know how to continue from there... but the problem now is that theres isnt any values coming from the char c...
