Just one point, it may be best to go for five LiIon batteries in series to give a nominal voltage of 5 * 3.6V = 18V, a charge voltage of 5 * 4V =20V, and a cut off voltage of 5 * 3V = 15V. The determining factor will be the lowest voltage that the scope will operate from. The external range, from your figures is 11V to 30V, so presumably the permissible battery voltage will be the same.
The battery charging arrangements need further detailing, but we can sort that further down the line. Best not to cover too much ground in one go.
spec
spec
