How to write string on specific line
Parth86
I am trying to write message on specific line of LCD. I wrote following program but LCD doesn't show the message on screen
8051 and keil
C:
#include<reg51.h>
#define port P1           /* Data pins connected to port P1 */
sbit RS = P2^0;           /* RS pin connected to pin 0 of port P2 */
sbit RW = P2^1;           /* RW pin connected to pin 1 of port P2 */
sbit EN = P2^2;           /* EN pin connected to pin 2 of port P2 */
void DelayUs(unsigned int wait);
void DelayMs(unsigned int wait);
void LCD_Command(unsigned char cmd);
void LCD_Data(unsigned char Data);
void LCD_init();
void LCD_goto( int x, int y);
void LCD_print(char* str);
/* functions for delay */
     wait >>= 3;
      while(wait--);
      while(wait--)
      DelayUs(1000);
/* Function to send command instruction to LCD */
    port = cmd;
    RS=0;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
/*Function to send display dato LCD */
    port = Data;
    RS=1;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
 /* Function to prepare the LCD */
void LCD_init()
    LCD_Command(0x38);
    DelayMs(15);
    LCD_Command(0x0f);
    DelayMs(15);
    LCD_Command(0x01);
    DelayMs(15);
    LCD_Command(0x81);
    DelayMs(15);
/*Function to position cursor on the LCD */
     int addr = 0x80;
     if(y==2) addr+=0x40;
     addr += x;
     LCD_Command(addr);
/* Function to print on the LCD */
       while(*str!=0)
       LCD_Data(*str++);
void main(void)
        void LCD_init();
    while(1)
          LCD_goto(1,1);
          LCD_print("Hello");
          LCD_goto(2,1);
          LCD_print("Forum");
Program output
compiling lcd.c...
lcd.c - 0 Error(s), 0 Warning(s).
jpanhalt
Most Helpful Member
The beginning of the second line is 0x94 (1,0).
However, if you "aren't seeing anything," that is probably not your problem. Can you print to (0,0) or 0x80? If there is gibberish, show us a photo. Do you have contrast turned up enough to see the faint outline of dark rectangles?
Pommie
Most Helpful Member
For a 16*2 the second line is address 0x40 = command 0xC0.
For a 20*4 display the second line is address 0x40 = command 0xC0.
For a 20*4 display the third line is address 0x14 = command 0x94.
For a 20*4 display the fourth line is address 0x54 = command 0xD4.
I suspect the contrast also.
Edit, as far as I can see, the code is correct.
Edit2, I take that back - your x and y seem to be in the wrong order in your goto routine.
jpanhalt
Most Helpful Member
Pommie, I suspect your line values and mine differ by an offset for ascii characters (0x20 - 0x7F). Do we know whether the OP's has that offset?
I saw this " int addr = 0x80; " and assumed it did.
Pommie
Most Helpful Member
The 0x80 is the command to set the address. So writing 0x80 sets the LCD address to zero which is the first character of the top line. The second line is at address ox40 and so the OP needs to write oxCo as a command.
However, in the code above the x and y are the wrong way around and so "HForum" should be displayed on the top line.
Also, y is indexed from 1 and x from 0.
Parth86
Pommie & jpanhalt
Sorry I forgot to tell you that I am working on proteus simulator but I think there is no fault in design because I have been worked with this design before. there is nothing wrong in design. I suspect there is problem in program
Pommie
Most Helpful Member
If you remove the gotos do you then get HelloForum on the display?
Parth86
I have done some changes in program and it work's. I can print message on first and second line
C:
#include<reg51.h>
void LCD_init();
     wait >>= 3;
      while(wait--);
      while(wait--)
      DelayUs(1000);
    port = cmd;
    RS=0;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
    port = Data;
    RS=1;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
void LCD_init()
    LCD_Command(0x38);
    DelayMs(15);
    LCD_Command(0x0f);
    DelayMs(15);
    LCD_Command(0x01);
    DelayMs(15);
    LCD_Command(0x81);
    DelayMs(15);
void LCD_goto( char x, char y)
   int addr = 0x80;   // start address
   if(y==2) addr+=0x40;  // are we on second row
   addr += x;    // add in the columns
   LCD_Command(addr);   // send to display.
void LCD_Print(unsigned char *string)  //Function to send string to LCD
int index=0;
while(string[index]!='\0')
  LCD_Data(string[index]);
  index++;
  DelayMs(10);
return;
void main()
unsigned char Messsage1[] ="Hello";
unsigned char Messsage2[] ="Forum";
lcd_init();
   while(1)
       LCD_goto(0,0);
       LCD_Print(Messsage1);
       DelayMs(50);
       LCD_goto(0,2);
       LCD_Print(Messsage2);
       DelayMs(50);
Pommie
Most Helpful Member
It makes no sense that you saw nothing with the code in the first post. What did you change?
Also, having the top line as line 0 and the second line as line 2 makes no sense. Change it to 0 and 1.
Ian Rogers
User Extraordinaire
Forum Supporter
Most Helpful Member
Loosley worded.. Looks very much like the code I gave you..
char message[] = "Hello";
Creates a message in rom... Therefore the LCD_print statement I posted will not work..
char message[8];
printf(message,"Hello");
will create the message in ram and will work... Remember a Rom pointer is different to a Ram pointer..
Parth86
char message[8];
Sorry but I didn't understand your point. I think I am doing mistake here
C:
       while(*str!=0)
       LCD_Data(*str++);
void main(void)
        char message[8];
        void LCD_init();
    while(1)
          LCD_goto(1,1);
          LCD_print("Hello");
          LCD_goto(2,1);
          LCD_print("Forum");
Ian Rogers
User Extraordinaire
Forum Supporter
Most Helpful Member
Okay... As simple as I can:-
8051 has a data space and a code space... Therefore in C we have two pointers.. One for code and one for data.
char message[] = "Hello world"; is static text... Therefore the compiler puts it in code space..
char message[8]; is non static and will be placed in data space..
This puts a burden on C programmers as this line:-
void LCD_print (char * message) will only work for data pointers..
void LCD_print(rom char* message) will only work with code pointers..
LCD_goto(1,1);
LCD_print("Hello");
LCD_goto(2,1);
LCD_print("Forum");
This is also wrong as x is columns and y is rows... Line 1 = (0 ,1) and Line 2 = (0,2)..
Parth86
void LCD_print(rom char* message) will only work with code pointers...
I tried it but program showing error
C:
#include<reg51.h>
void LCD_init();
void PutMessage(rom char *Message);
     wait >>= 3;
      while(wait--);
      while(wait--)
      DelayUs(1000);
    port = cmd;
    RS=0;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
    port = Data;
    RS=1;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
void LCD_init()
    LCD_Command(0x38);
    DelayMs(15);
    LCD_Command(0x0c);
    DelayMs(15);
    LCD_Command(0x01);
    DelayMs(15);
    LCD_Command(0x81);
    DelayMs(15);
void PutMessage(rom char *Message){
char i=0;
    while(Message[i]!=0)
        PutChar(Message[i++]);
  void main(void)
            LCD_init();
       PutMessage("Hello");
           while(1)
compiling lcd.c...
lcd.c(13): error C141: syntax error near 'char', expected ')'
lcd.c(60): error C141: syntax error near 'char', expected ')'
lcd.c(62): error C202: 'Message': undefined identifier
lcd.c(63): error C202: 'Message': undefined identifier
lcd.c - 4 Error(s), 0 Warning(s).
Ian Rogers
User Extraordinaire
Forum Supporter
Most Helpful Member
Parth86
Okay... You need to read your compilers help document..
Does it make any sense
C:
#include<reg51.h>
void LCD_init();
void LCD_goto( char x, char y);
     wait >>= 3;
      while(wait--);
      while(wait--)
      DelayUs(1000);
    port = cmd;
    RS=0;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
    port = Data;
    RS=1;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
void LCD_init()
    LCD_Command(0x38);
    DelayMs(15);
    LCD_Command(0x0c);
    DelayMs(15);
    LCD_Command(0x01);
    DelayMs(15);
    LCD_Command(0x81);
    DelayMs(15);
   int addr = 0x80;
   addr += x;
   LCD_Command(addr);
void PutMessage(unsigned char *string)
   int index=0;
  index++;
  DelayMs(10);
return;
 void main()
   unsigned char string1[] ="Hello";
   unsigned char string2[] ="Forum";
   unsigned char string3[] ="It's work";
lcd_init();
   while(1)
       LCD_goto(1,1);
       PutMessage(string1);
       DelayMs(50);
       LCD_goto(7,1);
       PutMessage(string2);
       DelayMs(50);
       LCD_goto(1,2);
       PutMessage(string3);
       DelayMs(50);
Ian Rogers
User Extraordinaire
Forum Supporter
Most Helpful Member
void PutMessage(const char *Message)
char i=0;
PutMessage(Message[i++]);
Just look at your code.... If you sent that code to the LCD instead of itself, it will work..
Parth86
I tried this before but it show error
C:
#include<reg51.h>
void LCD_init();
     wait >>= 3;
      while(wait--);
      while(wait--)
      DelayUs(1000);
    port = cmd;
    RS=0;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
    port = Data;
    RS=1;
    RW=0;
    EN=1;
    DelayMs(5);
    EN=0;
void LCD_init()
    LCD_Command(0x38);
    DelayMs(15);
    LCD_Command(0x0c);
    DelayMs(15);
    LCD_Command(0x01);
    DelayMs(15);
    LCD_Command(0x81);
    DelayMs(15);
   int addr = 0x80;
   addr += x;
   LCD_Command(addr);
  char i=0;
 void main()
lcd_init();
   while(1)
       LCD_goto(1,1);
       DelayMs(50);
       LCD_goto(7,1);
       DelayMs(50);
       LCD_goto(1,2);
       DelayMs(50);
compiling lcd.c...
lcd.c(76): warning C265: '_PutMessage': recursive call to non-reentrant function
lcd.c(76): error C214: illegal pointer conversion
lcd.c - 1 Error(s), 1 Warning(s).
EE World Online Articles
Loading
