how to connect PIC16F684 TO mplab debugger
dh_87
hi everyone, i am a student working on my software project. From the MPLAB debugger user guide, it says that 5 pins from the RJ45 port are to be connected to the PIC. Comparing the data sheet of the 16f684 and the MPLAB user guide, this is what i connected:
RJ45 PIC16F684 Function(s)
Pin 1 Pin 4 Vpp/MCLR
Pin 2 Pin 1 Vdd/5V
Pin 3 Pin 14 Vss/GND
Pin 4 Pin 13 RA0
Pin 5 Pin 12 RA1/Vref
additional connections:
-a resistor of 1K ohm is connected between 16F684's pin 1 and its pin 4
-an LED connected in series with a 470 ohm resistor at RC1
I just want the LED in PORTC to light up but the MPLAB program shows that its is unable to enter debug mode and unable to run target. Is there a problem with my connections? Thank you guys very much.
I guess it's the ICD2 you have? I don't have any experience with that one, but with the ICD2 clone from **broken link removed**
I've built it after reading about it on this forum, and it works like a charm.
I'm also using the 16F684 quite a bit; wonderful little circuit!
Pin 2 Pin 1 Vdd/5V
Pin 4 Pin 13 RA0
Seems correct for the PIC pins. I have no clue about the RJ45, though.
I'm not 100% sure, but I don't think you can "in circuit debug" the F684. AFAIK it's not that many PICs that have this possibility. But many (almost all?) can be programmed in circuit. (ICSP)
I've found ICSP to speed up my development considerably, compared to using a PICstart Plus and replacing circuits all the time.
Now I just make a change in the code, press F10 to build the project, press programming, and then bring the PIC out of reset. Guess I should think more, and program less; but that's another discussion... :)
