Hourly timer.
K1WY- Bo;;
I am looking for a TCXO chip or circuit to produce a pulse each hour every hour. I need this to be as accurate as possible but also single chip if possible
and 3-5 vdc operating voltage. Can anyone direct me to a RTC TCXO chip that can do this?
I will use this to sync, on the hour, old Western Union self winding clocks.
Thank you
Bill
Hello Bill, welcome to the forum.
There are one or two clock enthusiasts on the forum who may be able to make an exact suggestion, but I don't know of one off the top of my head.
My initial thought was that TCXO an a handfull of logic chips would be a way to go, but if you want to limit the component count, you could use the TCXO to give an exact 10Mhz in conjunction with a micro controller to do the division to 1 pulse/hour.
This of course would need some software programming knowledge, I don't know if you have any experience in that area, but it would give a low component count solution.
Jim GM3ZMA
Welcome Bill,
For starters:
This may not suit your accuracy specs, but might be OK for the clock you're calibrating.
Anyway, low component count and simple construction.
CBB K4NFF
I don't know of a 1hr part. but:
DS1307 has a output that will do 1hz. (1 second) but you need to turn on the output.
I can't find it now but there is a 8 pin IC that takes a color crystal down to 60/50hz.
I think SiLabs has xtal osc down to 0.1hz.
I have used a CD4060 (in your case two) to divide down to a very low frequency.
Start off with a color crystal or a watch crystal.
Not likely to find an off the shelf solution. I would go with a hacked 1.5V battery clock module to get a 1-pulse-per-second or 1-pulse-per-2 seconds clock. Then feed that to an 8-pin PIC and have it divide the clock input to a 1-per-hour output pulse.
Ken
You might be able to go with a variation of this: **broken link removed**
Note it tends to sync 2x/day and it might not have an extra pin available so you can create a 1 pph.
32.768kHz watch crystal coupled with a microcontroller will gove the best precision with minimum of parts.
You can also go a different route - catch radio or GPS signal - this will not drift at all.
