camerart
Hi N,And non-rechargeables last 5+ years![]()
I checked my re-chargeable batts and they are 4 years old, let's see
C
Smoke detectors are all AC with battery back up. With all 5 detectors laying on a table they are not connected to AC or each other, 4 detectors work excellent and the other 1 detector BEEPS none stop. The 4 good detectors are plugged into each room and they continue to work excellent while the 5th detector on the table continues to BEEP powered by a 9v battery.The house AC wiring being common to all of them, would make me check the AC voltage going to the detectors. If they are all on the same circuit breaker, AC voltage is even more suspect. If they are all on separate circuits, check the mains coming into the house. A problem with the power company's transformer can cause a low voltage problem in your house.
Because it's a PITA to change all the detectors and their bezels/wiring harnesses. Hopefully Gary can find a modern detector that uses the same bezel/connector as his current pigtail.Why didn't you dump it 4 months ago?.
