ikalogic
Hello,
I'll be using SRAM ICs from microchip
Here is the datasheet :
http://www.electro-tech-online.com/custompdfs/2009/08/22126B.pdf
In page 12, it is said that if i pull the HOLD line to 0, the I/O pins go to high Impedance. I am more concerned about the SI pin (or MOSI):
I want to be able to apply a voltage that swings from 0 to 25 volts on that pin, while the device is tri-stated. is this OK? Is there still a risk of damaging the IC?
Would it be better to add a 10K resistor in series to protect the input? if yes, will that affect the normal operation of the input pin?
I tried to contact microchip about that, but still no answer
thanks a lot for your advices
