budget minded
this is the THIRD forum i've joined trying to get help designing a simple class D sound system after drawing nothing but trolls who, if anything, sought to UNDERMINE my efforts instead of offering any actual help. i'm hoping the members here can help me solve a few issues that you shouldn't need to do ANY calculations for. my understanding of electronic circuits is VERY basic, so i need some expert help double checking my planned design.
it will start with 3 @ 12v7a batteries in series for a 36v circuit as class D amps like high voltages as you probably already know if you dabble in audio circuits. i'd like to use lighter lithium-ion rechargeables, but they're just too expensive for this system that still requires almost everything including some custom fabrication.
1. i'm planning on using a 2x100w class D amp for the mains **broken link removed** and would like to use this 1x400w amp for subwoofers that cross over at 70Hz/24dB per octave **broken link removed** . do you see any issue with that setup and those batteries? lithium ion batteries would have a much lower amperage rating, and i've seen them driving fairly high powered, but less efficient class A/B amps. i don't know how to calculate power requirements.
2. i wanted to buffer the batteries with a 1 farad car audio capacitor, but those aren't rated for 36v. other capacitors i've seen are more expensive with lower farad ratings. car audio caps aren't just cheap, but also come with mounting brackets need for installation. i don't know why i couldn't use car caps because even though this will be a high voltage system, it will only be 7 amps. i wondered if maybe i could run 3 caps in parallel to, in essence, divide the 36v by three to get 3x 12v. what i understand about caps is that you add their values in parallel like they're 1 cap and that a bunch of smaller caps will be faster acting than 1 big cap, but not how it relates to volts and amps, just farads. i figure a cap buffer would really help seeing that i'll be using such low amperage smaller batteries, but needing high wattage.
3. what sized fuse should i be using in this system? i figure if the batteries are rated at 7 amps, then i should get a fuse, more likely a circuit breaker that i can also use as an on/off switch, rated at 8 amps so the circuit doesn't impede battery output, but doesn't let it exceed it either. these kinds of questions are very hard to look up online, probably because i'm not using the right technical jargon to ask.
4. if the circuit is broken by a switch, then i should be able to directly tap each battery's terminals to charge them without having to pull them out, right? as there's no circuit, they can't interact, as i understand it.
5. similarly, could i directly tap individual batteries at 12v to power low draw items like line level EQ/crossovers and still maintain 36v across the main circuit? it would seem to me like that shouldn't be an issue
6. how would i integrate a voltage meter? i would have thought i would just insert in series with the circuit and it would directly measure the voltage (36v meters are harder to come by) but in reading specs on various, usually digital ones rated to even 100v, it looks like they all require ANOTHER 30v power supply which doesn't make much sense. isn't there such a thing as a self powered meter like the ones used in car audio caps? back to question two, what about maybe running 3 caps, all in series with individual batteries, and using those as 3 x 12v power meters instead of trying to figure out how to get another 30v circuit to power a single 36v meter.
thank you in advance to anyone that can shed some light on these questions that should be ridiculously easy for you, but that are above my head and very frustrating to try and solve with spam engines. if i can get a handle on these little issues, wiring everything up should be a piece of cake. i understand enough about electronics to be able to handle that without a problem, but system load rating? that's a whole other level of technical. i truly appreciate any help that will guide me to building this system right and SAFELY.
