Hello Friends,
I am a newbie and have to develop a solar lantern for my college project. The lantern should have following features:
1) Solar Undercharge and Over Charge protection
2) AC Adapter charging (I think we can use the same Solar Over and Under Charge circuit for this. Except we need to get appropriate voltage from the AC Adapter.
3) Mobile charging circuit
4) LED Dimmer (Push button types and not POT based)
5) 6V Battery will be added to store the power
Here is a list of the circuits I found on Web and planning to use:
1) 6V Solar Charge Controller - SCC2 10 Amp Solar Charge Controller
This circuit does not have battery over discharge circuit. Please help me incorporating it. Also guide me if the same circuit can be used to charge the battery either by Solar Panel or AC Adapter.
2) Mobile Charging Circuit
Found many circuits but none on 6V battery. Please advise what can be done to modify 12V Battery source to 6V battery source. Or if you have a 6V it would be a great help.
3) LED Dimmer
Again same problem. I have found many circuits but none on 6V battery. Please advise what can be done to modify 12V Battery source to 6V battery source. Or if you have a 6V it would be a great help.
Any input will be appreciated... Need your valuable comments...
Thanks a lot
Dev
3) LED Dimmer
Thanks a lot
Dev
