Help please (digital clock)
jonnythesurfer
Hi there. For an A-level project we have to create a clock. I have designed a digital clock where I create the 7 segment displays. I don't have to create the electronic mechanism to do this but would like to create a working clock. I was thinking of buying a very cheap digital clock and removing the LCD screen re-wiring it and inserting my 7-segment displays, made using LEDs. I guess this would be possible and if so is it easy and how is it done? (any wiring diagrams?) if not is there a simple way of creating the mechanism needed which I can do at school for as little money as possible?
Any help would be much appreciated thanks
Jonnythesurfer
You just take out the internal parts of the alarm clock and fit your new display in. Make sure to have enough space for the new display too.
That may be a bit tougher than that. Depending on how the LCD display is wired/features and such, an LED display is not a direct replacement for any ole' LCD display
The LED cannot replace LCD directly. Because a LCD is usually controlld by microchip, but its code and port cannot match LED.
I think you'd better find a circuit and build it yourself. It won't cost you much time.
