Hi all,
I want to build myself a little amplifier as part of my hobby, which I will then use to power a couple of speakers. I like the idea of it as it'll be small and I could transport it around so it'd be ideal for use with my other hobbies.
I want to use parts I already have on old chassis and things in the shed, so I got an old TV chassis and found the stereo amplifier IC - TDA2615 - which seems perfect for my basic needs; it seems simple and needs few external components.
My needs: stereo amplifier circuit to take outputs from, say, tape recorders, computer sound cards, etc. Amplifier to take around 9 to 12V DC, and to output to a couple of 8 ohm speakers. Circuit to be small and not require components I don't have here already.
All I can find is a datasheet for the TDA2615 which shows a test circuit. I was going to copy this test circuit since I don't know how to design one around the TDA2615 myself. Trouble is, part of the test circuit doesn't make sense to me.
Here is link to datasheet, page 8 has the test circuit I wanted to copy:
https://www.electro-tech-online.com/custompdfs/2005/01/TDA2615_3.pdf
However, to save trouble, here are the relevant images:
Here's what confuses me: the input voltage's negative -Vp goes to the negative of a 2200uF capacitor, with the positive of said capacitor going to 'ground'. It also shows pins 3 and 8 of the IC going to ground and the negatives of the speakers, etc. So, if -Vp isn't ground, since it is kept apart via a capacitor with the positive of the capacitor going to ground, what exactly is ground? Are the parts that are shown to go to ground actually going to the negative of the audio inputs, so the whole 'ground' network is based upon the input ground, with the voltage -Vp ground being kept separate? If I haven't explained this well, please ask, as you'll need to understand my confusion in order to answer to it, and others may see nothing confusing in the circuit at all...
Another thing, what is "INV1,2" - stated as: inverting input 1 and 2 - it shows it being grounded, but what exactly is an inverting input? What should or normally would go there? It confuses me as the audio inputs are named 'non-inverting inputs'.
Lastly, I want a volume control on here. I know it would require two potentiometers so as to keep the stereo channels separate, but where would I place them? In line with the audio inputs, so when the resistance is high enough, no audio input goes into the amplifier IC and hence no sound comes of of its outputs?
Thanks to anyone who answers this! Also, if you think the design could be improved, changed to make is easier, please go ahead.
Thank you,
James
Thank you,
James
