hi all
i am thinking about making a device which fitted to any modern car will illuminate the headlights for a delay after the ignition is switched off, but i am concerned about modern cars no longer being wired in parallel (possibly things like the CANBUS systems etc).
I am guessing that it's not really practical to connect the +ve terminals of the left headlight with the right headlight, in case it flags up some error on the dashboard
my solution would be a high current diode on each light
My Relay ----->|---- (+ headlight 1) -----Gnd
Car's circuit --->|---
My Relay ----->|---- (+ headlight 2) -----Gnd
which would effectively isolate the lights from each other. However this presents another problem in that a standard 55 watt 12 volt car halogen headlamp is (obviously) nearly 5 amps, and I can't find a diode suitable, that isn't a schottky one
so the question is - does anyone know of a suitable diode?
i assume schottkys aren't applicable because of their low forward voltage, and low reverse current handling (they will need to handle considerable reverse current i would have thought).
i guess the specs would need to be (but i could be wrong, im very much a novice):
-Vfwd = 12+vdc
-Vrev = 12+vdc
-Ifwd = >5A
-Irev = >5A
thanks!!
-Vfwd = 12+vdc
-Vrev = 12+vdc
-Ifwd = >5A
-Irev = >5A
thanks!!
