Funny Images Thread!
Well, seeing it's quite here...and we all like Bacon....here is a Trotter that decided that it doe's not want to part of anyone's Breakfast...
I introduce the"escaping"...breakfast?????...Very determined and hardy...
No slaughterhouse for this brave Guy. Classic jump and roll..and stand up. Nothing broken and free...
A whole new World waiting out there.....someone else will end up eating him. Sooner or later.
Crazy hey....all the effort for nothing :arghh:
This is not funny at all....maybe makes one think...everything un electronic related...videos etc grouped in one place....funny or not.
You could tell that pig was seriously injured by the way it was walking. Probably would have been better for it to have died on impact or just gone to the slaughterhouse :eek:
Going to celebrate Midsummer.. Finnish style.
http://en.wikipedia.org/wiki/Midsummer
Friend of mine after midsummer party.. no need to censor the face, it's already done.
Maybe someone, with a speech impediment, got a wish from a genie and actually asked for a million bucks?
Created for facebook:
Some tools to be aware of and their uses:
  1. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
    WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, “Ouch….”
    ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
    PLIERS: Used to round off bolt heads.
    HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you’ve been searching for the last 15 minutes.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
    EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle.
    TWEEZERS: A tool for removing wood splinters.
    PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack.
    SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise but used mainly for getting dog**** off your boot.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn’t use anyway.
    TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
    CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry-bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The home mechanic’s own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, “the sunshine vitamin,” which is not otherwise found under cars at night. Health benefits aside, it’s main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    AIR COMPRESSOR: A machine that takes energy produced in a coal- burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads.
    PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50¢ part.
    HOSE CUTTER: A tool used to cut hoses too short.
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
    MECHANIC’S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
    DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling “DAMMIT” at the top of your lungs. It is also the very next tool that you will need.
    EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
    AND If you have young daughters you will find a few extras…
    40.00 snap on 1/2″ 18″ extension: adequate post for horse shoes when pounded in using small sledge hammer
    60.00 snap on ratchet: adequate for use as sledge hammer
    Set of Craftsman screwdrivers: perfect for baby tomato plant stakes
    All other tools; perfect for lawn ornaments
TOOL CHEST: A marvelous, expansive storage device that can be used for organizing an amazing assortment of hand tools and other useful items that has the unique ability to, at critical moments, hide the tool you need.
I came across this guy in all his sartorial elegance and thought, "To hell with the correct PPE, we want Shabby Chic Workwear!"
He had just been up in a cherry picker, cleaning a display aircraft.
2014-06-27 18_26_45-Microsoft PowerPoint - SSTesla.pptx - solidstatetesla.pdf.png
had to share this in here too, just hilarious :D
^^^ Suarez really screwed up..
Biting....remember Tyson taking a Bite of an opponents ear..
Biting is desperation...no excuses. So he "Suarez" is history....animal tactics belong in a cage.
So, in the interests of keeping things on track here, I edited my last post.
Ever vigilant
tvtech
I watch myself :wideyed:
It is the third time he bites a player during a game!
