Ferrite Bead
kinarfi
I was advised use a ferrite bead and a 10Ω resistor on the gate of a power Mosfet and the project I'm working on needed 2 of them and I only had one and an idea came to me, what would happen if you drilled a hole in a piece of aluminum and used it instead of a ferrite bead? It would still create some inductance, wouldn't it? but how much? I tried to measure the inductance of a piece of wire with a ferrite bead on it and it couldn't be measured, not with my equipment, or what would happen if you used a small washer? A ferrite bead is made of powdered magnetic material and is not conductive, where as aluminum or a washer is. I kept looking until I found a 2nd ferrite bead, but I still wonder what would happen with the aluminum or the washer, any one know?
Jeff
The whole point in using a ferrite bead is that it is ferromagnetic. It has a high permeability which increases the inductance of the wire passing through it. Aluminum is not ferromagnetic, and has a permeability roughly equal to that of air.
Probably iron bead is little better than aluminum at least. Once I also was searching ferrite beads and getting nothing. When I went to a garbage store, there were tens of beads and tens of VERY rare and exciting parts used in damaged and old kits. I scrapped them free because they do not know what they have on their recycle bin. :)
According to your "advisor", what is adding a ferrite bead to the gate of a FET supposed to do?
Adding a bead (to stop ringing on the gate) but it might cause more ringing.
The gate has capacitance. Adding inductance does not sound good. You need a bead that looses power. AND A resistor to reduce the ringing.
I would have to search to find who my "advisor" was, but I seem to have fewer FETs destroyed and I have seen it on other FETs I have salvaged, mostly from power supplies for servers.
My interest has been piqued by this thread, so I thought that I would run a few tests to see the effect of various beads and a steel nut.
Using a spectrum analyser and tracking generator and a little test jig which is shown with the beads and nut in the first picture:
With the analyser sweeping from zero to 100MHz, the response of the straight through connection is shown here:
The vertical scale is 2dB per division. The big dip at the left of the screen is the zero frequency marker.
Putting the steel nut on the wire shows practically no change from the straight through connection:
The small bead gave some attenuation as shown here:
The larger bead gave a bit more attenuation, as shown here:
Remember that this is taking place in a 50 ohm environment, where the circuit impedance is something else other than 50 ohm the attenuation will be different.
Going back to the original question, a steel nut does nothing, and aluminium washer is likely to do even less.
A capacitive discharge with desired C ratio Csource/Ciss and driver ESR to limit current will shut off a MOSFET faster
Then slow turn on gives good dead band for bridge control. But most just use R//Diode with voltage driver to control non-linear ramp.
Remember Gate charge steps rapidly during switching time which results in dynamic current spike then low current in either Vgs state. In this case Ic=V*dC/dt dominates over C*dV/dt.
where Q=CV and when both are a function of time Q(t)=C(t)*V(t) and Q(t) has a step function near threshold voltage. See Q vs Vgs.
https://www.onsemi.com/pub_link/Collateral/AND9083-D.PDF
Hi there,
There is a chance that the permeability of the ferrite is about 10 times that of the steel, so if you want to do one more test try it with ten steel nuts on the same wire, or wind 10 turns through the center of the nut as if it were a toroid, and see if you can get a reading that is closer to the single ferrite bead.
The permeability of the steel is probably about 100, while that of the ferrite could be 1000.
A capacitive discharge with desired C ratio Csource/Ciss and driver ESR to limit current will shut off a MOSFET faster...
I understand gate charge control which all happens in the 0 to a couple of MHz range, but I was wondering what a bead that can only produce effects at >50MHz has to do with it?
gate charge effects are not 0~ couple MHz rather,
0 to 1 μs.
and 20ns for a good Mitsubishi 150A IGBT
Which is ~ 30 MHz
But too fast and you get EMI problems.
In my experience with RF and logic noise a ferrite bead is like adding 5 pF across a 50 ohm driver. The lossy part comes from the driver but in the bead it is absorbed in the ferrite.
1/1us = 1MHz!
Ferrite beads are useful when the rise time is measured in 10's of ns.
1/20 ns = 50MHz
There are two categories of ferrite beads with hundreds of sub cat.
1) high mu ( low metallic oxide content, high resistance with probe, good for video signals on VGA cable , SMPS cables, DC cables, CM chokes for data, HDD read/write cable to heads etc.
2) low mu ( high metallic oxide content, low resistance with probe/ohmmeter, good for UHF, microwave )
Tony, you missed the point. Nothing around the gate of a FET is happening at much over 1Mhz.
Not in my experience. A lot happens up to 30MHz in high performace MOSFETs and IGBTs with about 5kV/us
In fact Mitsubishi IGBT's are so fast they have to introduce soft switching technology to reduce EMI issues > 100MHz
Watching with great interest,Untitled.png the bead's effect on the circuit would only be at the rise and fall of the square wave, output of a LM555, so wouldn't that be the equivalent of a frequency greater than 10MHz since wave form is linear and not sinusoidal?
The DIP switch PS51259-A has a Trr of 0.13µs (typ) with inductive load.
sixth- generation pseudo-0.35µm trench MOSFETs which have lower RdsOn could be faster without mitigation.
If slew rate control of load is desired ferrite or additional gate capacitance may help, but degrade deadtime control in bridge designs and worse increase SOA dynamic power losses in high f PWM switches.
Thus slew rate control with filters is a tradeoff between switching loss and EMI so ferrite or additional C on gate is not wise for high speed PWM
Of course there may be up to 20 harmonics in slew rate and Mitsubishi geometry in MOSFETs and IGBT's tries to suppress the harmonics with nonlinear filtering effects in their IGBT modules.
Typ. MOSFETs may not have same response.
When it comes to MOSFET design, I consider Mistubishi the experts, which is why they can design modules with ganged IGBT's to switch a gigawatt of power. So for low power applications like this OP"s , I recommend learning from them.
ESL on both the gate and the load is bad practice for high speed switches. Generally they choose Litz wire and low ESL cabling to reduce transient effects from inductance getting referred back to gate capacitance with resonance and SOA issues. the advantage of IGBT's over MOSFETS is the bipolar output reduces Qg.
