ADWSystems
I have to agree they are pretty cool. I'd have to look for a second source before I'd be allowed to include them.
In engineering circles it's call "feature creep".........................
I am veering further and further away from my original super simple idea of a self-contained, 110vac electromechanical system to take control of my basement drainage needs.
In engineering circles it's call "feature creep".![]()
Hello everyone,
I would like to build a circuit, hopefully using only components that work off the regular household 110vac supply (relays, neon lamps, etc.) , which would do the following:
It would receive its power from a regular household AC outlet, and it, in turn, would power two basement sump pumps, both located in the same sump, submerged at the same depth (unlike the typical low voltage backup pump stacked configuration, which has floating switches at different heights). The circuit should alternate between pumps 1 and 2 as demand arises, thus extending the life of both pumps and also allowing for one of the pumps to act as a backup in case the other pump dies. In addition, a few lamps would provide the following feedback information: Two lamps, one assigned to each pump, would indicate which pump is currently active, whereas a second set of lamps would only turn on (and do so permanently) if either of the two pumps dies, thus indicating which pump needs to be repaired or replaced. A buzzer to provide audio feedback in case a pump dies would probably be a nice addition.
Can this be accomplished with a strictly electro-mechanical circuit that does not include a microprocessor or other electronic components?
Thanks in advance for any help
Arsene
My solution to this situation was to use two power relays one for each pump and one cross wired relay to alternate the pumps as called for by two floats set at different levels Lead and Lag with a strobe light to indicate when Lag float is in operation. sent a rough drawing of the circuit can send pics if needed.
That's a nice idea, however the original poster stopped responding almost 4 years ago so we have no idea how this all worked out.
