Driving Motor With Two Transistor
hi all
i have just designing my new project
Which can be reduce a the quantity of Transistor in driving motor
is it ok to use this circuit in driving motor with PIC
because im only using small motor ?
Unless the motor operates on a <20 mA of current (unlikely) then you will need the transistors to boost the current.
And Transistorman, you need a little better understanding of transistors. In your connection the base-emitter junctions are shorting the outputs to ground, since there are no base resistors (and what is the purpose of those transistors anyway?).
thanks
for your correction
i will put some diode to prevent PIC from shorting :)
OK, let's try something. Pin 6 of the PIC is High and Pin 7 is low. From there tell us in theory exactly what is happening? The transistors aren't doing anything that I can see.
Ron
The base-emitter diode of the transistor that is turned on is shorting the output of the PIC to only +0.7V.
Therefore the PIC will burn out and the motor does not get enough voltage to run.
