do you mean the reference designation of the components? if that is what you refer, i've done it before, but for tightly packed components, its not recommended because it may be a cause of shorts.Screech said:Do we use the double sided copper boads to etch links on the other side?
do you refer to the board size? based from experience, double sided boards sometimes don't really reduce board size. it still depends on the circuit you are trying to make. but most of the time, double sided boards reduce board size specifically for complex circuits.Screech said:Do we also use the double sided boards to make the circuits smalled in size?
Is that what the other copper side is for?
