Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
hii i am sharing the DIY flashing leds project here... this is fun with leds week end project is from "MAKE" magazine i have attached all the source here including PCB layout and use eagle to open the files....enjoy..........
The LEDs simply flash on and off all at the same time.
The value of the RBASE is too high for the 2N2222 to turn on that much current (about 220mA). The base current should be 22mA then RBASE should be 300 ohms.
Go down to at least 500 ohms for the 2N2222 base resistor otherwise it will not fully saturat and may over heat. Not all posted projects are right even though thay may work. Andy
Some 2N2222 transistors might work if the base resistor is as high as 1k ohms but some will not work. If the base resistor is 300 ohms then all passing 2N2222 transistors will work.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
