Discharging effects
Because AC currents have alot of different paths and AC currents are bi-directional and can reflect back to the input stages or around another path?
What is the purpose of knowing all the currents in circuit? It makes no sense.
But knowing you hate mathematics and do not want to deal with it use some SPICE simulation programe. But try some knitting first.
Because i want to know how the circuit work you have to understand the AC current polaritys, path ways, discharging bi-directional to know how electronic preamps,mixers,power amps etc work and how to read a schematic more in detail how the AC currrent go
Understanding how circuit works requires much more than knowing all currents or voltages in it. Your way is wrong. It will lead you nowhere.
But you must be able to calculate specific current or voltage. To do it you must use mathematics.
I put my volt meter to test the Voltage
Testing Current is way different because really which way is it going because Current is "Bi-directional" how do i know which way current is flowing? the Ampere meter doesn't have a "Direction of current flow" is just give measure's current
Its really hard to measure discharging currents because of the amprere Current meter
What is the Theory behind discharging currents and where do they go which paths?
1) I don't even think about capacitors charging and discharging in AC circuits. The impedance of a capacitor at a certain frequency is important and is simple to calculate.
2) The only reflection I think about is that an unbypassed emitter resistor of a transistor appears as an impedance to ground at the base multiplied by the gain of the transistor. Tubes are forgotten history for me.
3) Preamps and mixers have a few coupling capacitors and it is easy to calculate their impedance at a certain frequency to determine their effect on low frequency roll-off. The same thing applies to capacitors across emitter resistors.
4) Modern power amplifier circuits are direct coupled and don't use capacitors to couple signals except for an input cpoupling capacitor which has an impedance at a certain frequency which is easy to calculate.
5) I don't look at AC current polarities because they don't exist. AC doesn't have polarity. NPN and PNP transistors have polarity which is easy to learn.
bloki, take a chill. Hurling insults at everybody will not help the situation.
Covering the bases for the AC circuits you described generally spans two or three college engineering courses. Because of this, I'd really recommend because you need to know all of it just to get started with AC. This is really a matter for a new thread, but I can cover the basics if you have any specific questions on a circuit. walter, what is your math/electronics background? I mean are you familiar with applied calculus and mesh/node analysis, because those are essential to what you're asking for?
Current may have all sorts of waveforms. It can be pure DC, pure AC, it can have DC and AC component, it can have impulse shape, it can be periodic or aperiodic... Frequency of AC component can be from very low to extreemly high. So as the voltages.
Your digital handheld instrument has a limited capabillity in this respect and can not serve you in the most of the cases. You should use oscilloscope with propper voltage and current probes. Some aspects of the signal can be observed by using spectrum analyzer etc.
Knowing the amount of all currrents in a circuit will tell you nothing about how circuit works.
Thanks guys
Just alittle electronic math i know from my electronic book has electronic math formulas but this is very very basic to you guys im not that smart
So what test meter would tell what direction Current is flowing in ?
Because Current is Bi directional it can go anywhere in the circuit forwards, backwards, up and down and around
Just a comment.
You are using FAQ method to collect partial informations about electronics. This is not the way to learn it. You will be more and more confused and you will have more and more questions.
You must build your knowledge step by step from basics to more complicated matters. Knowledge must be build up not only collected.
Finally you will not be able to see a forest because of trees.
Walters,
by now, please understand that NO ONE CARES ABOUT CHARGING AND DISCHARGING IN A CIRCUIT unless the circuit is specifically about it.
in fact, as nigel said, IT IS POINTLESS TO SEEK INFORMATION ON IT.
Buy a multimeter, and experiment with it.
and go to your library and read a whole bunch of books.
you can tell by the display. Ifyou see a -ve sign, it is flowing the wrong way. but, I was taught that current flowed from -ve to +ve. so how could it be bi-directional?
It's better to understand it by looking at polarities. for example, the anode of an LED should go to +ve, and the cathode to -ve through a resistor.
mstechca said:
[ but, I was taught that current flowed from -ve to +ve.
In which case you were probably taught 'wrong'?.
Conventional current flow is from +ve to -ve, but electron flow is from -ve to +ve. Confusing, but it's that way for historical reasons as much as anything else. From a design or electronics point of view it doesn't really make any difference - you simply connect your meter the correct way round and it reads correctly.
Wrong! Many circuits use a dual supply with negative voltages and currents.
A PNP transistor circuit frequently uses only a negative supply and all voltages and currents in it are negative.
Thanks guys
When measuring Current how do you know where to put the negative black probe and the Hot positive probe because if you switch them around it still measures the current but the polarity is different how do you know really which is the right polarity?
Can someone please look at the schematics i posted on the hyperlinks and take a Red pen and draw "Arrows" showing me where the currents directions are and take a Blue pen and show me the Discharging currents please just have a bunch of Red and Blue arrows showing me the directions of the currents please
New facts. You do not use logic. When measuring DC you do not need to know the polarity of voltage, instrument will show it to you. If negative sign appears it shows that your prediction of polarity was wrong.
Why? Looking at charging and discharging currents and their directions is pointless. The only parts in a circuit that have charging and discharging currents are capacitors:
1) Supply bypass capacitors charge the moment the circuit is switched on and remain charged until the circuit is switched off, unless the supply that continuously charges them is overloaded.
2) Coupling capacitors charge the moment the circuit is switched on and remain charged until the circuit is switched off, unless the program's frequency is lower than their cutoff frequency.
Instead, you need to know how the circuit's tubes and transistors work, then you will be able to "read" a schematic like a book. :lol:
Thanks guys
[/quote]When measuring DC you do not need to know the polarity of voltage, instrument will show it to you. If negative sign appears it shows that your prediction of polarity was wrong.
But what about AC currents because its alternating?
Things may look more complicated. When we speak about charging or discharging of capacitors we have in mind exactly what audioguru said. But any change of current through capacitor is causing change of electric charge in capacitor and as consequence a change of voltage across it.
walters, I'd really recommend getting all the DC fundamentals down first.
AC is like is cold water: you've got to go in one step at a time. Trying to plunge in all at once is just unnessary torture. Engineers don't spend 4+ years in post secondary by accident.
