Hi everyone thanks for looking.
I am working with the TAS6422 Class D digital Amp from TI
https://www.ti.com/lit/ds/symlink/tas6422-q1.pdf
The DIR9001 digital audio interface receiver (optical in) from TI
https://www.ti.com/lit/ds/symlink/dir9001.pdf
I copied this design from TI off of their eval board for the TAS6422 and DIR9001 combo.
https://www.ti.com/lit/ug/slou464a/slou464a.pdf
The problem is this: The WARN pin is immediately asserted, and I have no sound. Open drain, I have an LED tied to it. Datasheet will tell you WARN pin asserts for three reasons: Over temperature, clipping, and power on reset. Scope shows it turning on within 2ms after a 2.2A spike, just as 14.4V begins to ramp up. 14.4V takes about 15ms to ramp up.
PVDD and VBAT are tied together getting 14.4V. VDD gets 3.3V.
On DIR9001, I tied the external oscilator input to ground to force the DIR to use PLL. I also brought CKSEL low to facilitate this.
Thank you for your time. I'll upload a schematic soon but if someone could help out with any ideas in the meantime, I would appreciate it.
