D-flip flop alternative
yyyyaser
a positive edge d-f.f for example:
saves the value fed to it at the time of the positive edge of the clock , and keeps giving that as an output until other input is fed at the time of positive edge .
what if the circuit is too simple to have a fn generator to produce the clock .
is there a device that does not need a clock input , and takes an input any time and saves it , and keeps giving it as an output until other input is fed to it any other time.
thanks in advance .
Just put a couple of gates in series to generate a clock pulse slightly delayed from D input.
T-gate flip flop.
You still need something to reset FF or use a R-S flip flop.
Then you can use a AND gate and a INVERTER to produce a short spike whenever the voltage from the generator shift from low to high:
With no clock, how does your mythical storage device know when to sample (and latch) the input?
Then it seems you would not need a storage device at all.
Just continously monitor the input.
the problem is the input is only a pulse , so i need to save this pulse value and keep it as an output , until another pulse comes .
but i think those who commented before you solved the problem pretty well , thanks any way .
