Crazy Idea
Kane2oo2
Hey guys,
somebody recently sent me a link to this circuit
It has got me intrigued.
They said to work, the circuit needed to run (be switched) in resonance, so as to reduce impedance.
Also the resistors need to be non linear type so as when the back emf flows they have very low resistance.
They say the extra energy comes from the permanent magnet and its changing field.
Can somebody explain why this wont work? I know its got to be a simple reason but i cant for the life of me see it.
Kane
All electrical circuits and mechanical systems have losses. Which means some part of the applied energy is always wasted - as heat or friction.
The circuit in the link will have not only the normal "copper losses" in the windings but there is the additional deliberately introduced loss in the two resistors. ("Load" resistors? Crazy. The accumulator would be the load.)
Energy is taken from the accumulator when the switches are closed. Some of that energy is lost as heat.
In order to charge the battery you must replace not the amount of energy extracted, but a bit more than that to allow for the (less than 100%) conversion efficiency when charging.
So there are three easily identifiable losses. The copper losses, that in the two resistors and that in the charging process itself.
In a word - impossible.
