Continuity Tester Project
I am talking about an actual 'real world' electronics shop. Not eBay and websites. Things are different in the 'real world' My profit margins would be textbook thick.
I will be so great to have such a shop were I live.
Where is you shop located?
Thanks,
PRPROG
I know this is minor, but for the unused opamp, I like to pull the inputs to different potentials, just to ensure no ringing and you know the output state.
Thanks for point this out. And I agree it might oscillate. I have just fired up TraxMaker and made the amendments to the PCB. Be nice to get the board a bit smaller so that it can fit in the tiniest of project enclosures. Project like this belongs in an box for all practical usage. The prototype works well on my bench, so I am going to run with the design despite what you may or may not think of it. It works. It is cheap. Simple as that.
The shop is located near a prison in Australia. Long bay jail. This is an max security prison for ***********.
Give it a rest with your un-necessary references to various sexual stereotypes - MODERATION
This is a continuity tester as well as a LED tester:
Nice board. Too rich for me though.... I have to make mine from scratch. No silkscreen printing. No solder masking. Single-sided only.
Here's one that I did a while back:
img02-jpg.92098
Works out to be about $2 plus labour. Gets even cheaper if I can step a few of them up on one large board and guillotine them into pieces.
How are you going to produce this?
Completely in-house. Manual labour. Laser printers. Thermal transfer paper. Blank copper clads. Chemicals. Guillotines. Zip-lock bags... for parts...
AUD 14.95 in real life retail shop (batteries not included)
If you use a PCB manufacturer, you will go below the cost of raw materials at quantity of 100 or less. You will get an added benefit of solder mask and silk screen (although some manufacturers will do bare boards too). It will happen at much lower quantities if you consider reducing PCB size by using more compact double-sided design.
Hell no... I'll do the whole thing myself. Keeps me busy and out of trouble. Plus I do not support the notion of cheap overseas labour where people are working with dangerous chemicals such as ammonium persulphate all day every day for 2-dollars an hour. We are taking advantage of slave labour to fuel an hobby here...
My first thoughts are about sledge hammers and nuts...
A more positive thought is:
Why not make a meter to measure low resistance, say less than 5 or 10 Ohms, and have an adjustable alarm point setting so that as you are "buzzing out" a cable or whatever, the thing will sound to tell that there is continuity if the resistance is less than some value set by the user, say 2 Ohms.
If you work in the auto service industry, you'll learn about decade boxes that are used to simulate and troubleshoot sensors and dash gauges. These decade boxes have resistances down to 0.025 ohms, allowing for wire resistance.
Jim this project presented here does exactly just that. The threshold / adjustable alarm point is set by turning the trimpot. It can be set from anywhere between a few milli ohm to a couple of hundred ohms.
I now have this boxed up... and it works a treat! ...
a-jpg.92262
b-jpg.92263
All you may need is a 9v battery, resistor, piezo sounder with built in oscillator, two wires with probe endings.
I once made one for an assembly line that tested cable harnesses and they were happy with it.
Yeah of course you do whatever you can get away with if it is just a job to you. You are there to satisfy the customer and get paid. No more no less. If the customer pays for the job it means they are 'happy'
Most of us here are geeks though. It is not just a job and a pay cheque. Genuine passion for the desire to create works of originality. Making money from it is a cherry on top of the self-satisfaction and merit.
I was a test technician. They were assemblers that could not always have access to an ohm meter.
I built it for fun for them. Put it in a cardboard box. I forgot to say the resistor went across an electrolytic capacitor to discharge it.
The sounder made a kind of sigh if the continuity was good. The gals liked the thing. Made them smile.
My point was it can be complicated or very simple. Could be a battery and bulb.
I did not mean to criticize your work.
I think we need to put this into perspective :D
'Value added features' - he's hoping to sell this device as a kit, and you're not going to make any money selling a battery and light bulb in a cardboard box. The added features of this design, plus the fairly impressive appearance, means it's got some sales potential - the fact that it's actually much higher performance is probably only of minor importance to the target audience?.
