DerStrom8
Super Moderator
Anyway, if this is an arc thing, then usually the open circuit voltage is set higher. This one lamp I had, ran at 22 A and 40 V when operating. The open circuit voltage was 80 V and the ignition voltage was 40 kV. The arc moved in the bullb. There was a similar bulb that had arc stabilization and it had to be able to move the voltage quickly to maintain intensity.
There are going to be certain things in the environment that might extinguish the arc, if the environment is air. Maybe even an open door.
Yea, I agree John and I are on the same page. It just so happens that I took 3 kV HV power supply design out of a early electronics publication and did an experiment entitled "Electroculture in Radish Growth". It was an Honorable mention in a regional science fair in high school. The supply crapped out in the middle of my experiment, so i opened up a small TV and used the HV anode for the rest of the experiment. I even incorporated a key switch for safety. They key switch was made from a cabinet lock and a microswitch.
Sorry, no arcs.
Nice story KISS
I presume the host is going to protect the experiment from environmental factors such as small gusts of air, etc, since he mentioned it will be in a "controlled environment". I don't think that's anything we'll have to worry about.
Regards,
Matt
