Compass radians to direction calculation
Here's a test showing XZY_RAW with no calculation, and some numbers to look at:
C
  • XZY RAW.txt
C
The values seem to be way off, if my calculations are ok.
COMPASS PCB HB LB calculated/ degrees
10 X 255 213 Y 0 119 20
40 X 255 95 Y 0 79 64
50 X 255 61 Y 0 48 76
60 X 255 33 Y 0 12 79
90 X 255 11 Y 255 117 120
120 X 255 75 Y 254 0 160
Hi J,
Any ideas why they appear wrong?
C.
Did you have the compass, magnets or iron... near the chip when measuring.
Currents near the chip might affect the results?
HMC5983 has a self test feature, which you could try.
Hi J,
The test PCB I've been using is a temporary measure, and the HMC5984 hasn't been properly setup, as it was uncertain that any results were possible, also there are metal objects including the brass compass, around that could affect it. I am making anew PCB, and once everything is fixed, it will be worth setting all of the details.
If the results, are somewhere near what should be, then at this stage it seems fine.
C.
I'm better at visual than calculations, so I made a compass wheel.
I can now see a pattern that will help me figure it out. There are 4x circles corresponding to XHB, XLB YHB, YLB
Hope it helps.
C
Hi J,
Regarding the self test feature. Does the module need to be in it's finished set-up, i,e, in the hardware, for the self test to work, or if I run it, will it work for all circumstances?
C.
I've got a bit tangled with the 'self test'
Will someone check my settings for the test, also my normal running settings, from the 'Self test.jpg, please?
From the results on the screen, it appears that the self test, and settings are ok.
C.
I'm getting a bit more familier with the 3 Axis compass technology, as time goes by, and getting various results. It seems as though there are two ways of compensating for errors. 1/for hard iron affects and 2/ For soft iron affects.
I've just come across a Compass module viewer that looks interesting, and can visualise the effects of nearby metals etc: https://diydrones.com/profiles/blog...oft-iron-magnetometer-calibration-for-dummies
It uses serial DATA from the module to give results. See attached.
EDITED
C.
