common emitter circuitry.
okay let me see here. the collector resistor is to prevent over current/voltage to the collector. the base resistor is to prevent the same to the base. the emitter resistor will determine the output voltage/current for a CE is this right?
In the case of a saturated switch, the resistor limits the current.
But in the case of an amplifier, you don't necessarily need a resistor since the collector current can be determined by the base and emitter voltages and resistors.
Yes, the base resistor limits the base current and prevents too much voltage being applied to the base.
I don't understand what you mean.
The emitter resistor in a CE amp is part of the biassing arrangements.
AllVol said:
I assume you were talking about me?
No, I wasn't talking about anyone. . . Just trying to say something that sounded funny.
Guess I failed:(
okay i've been reading until my eyes hurt and have yet to learn exactly what goes into biasing. i've order elecronics for dummies and sent the money order out already but can some one real quick explain the process of chosing resistors and what not for biasing?
For linear amplifiers? For switching? (I know, you're gonna say "yeah!")
oh yeah and callme lame but i don't see how the V-out which is above the transistor in the CE schematic can be efected by the base I/V i would think that all the V/I would run the path of least resistance through the out put at all times. i'm gonna have to put the circuit back together, and play with it some more
