coloured code
large_ghostman
Most Helpful Member
anyone know how you get the code to be coloured when using the code tags? i have seen some on here but not sure how its done
ok thanks
tried and it didnt work!! can you do a screen shot of a page edit showing what you mean?
LG, just testing it out,,, sorry no luck at my end,,,,:confused:
Code = C
void Slow_Delay(void)
int i, j;
for(i=0;i<4000;i++)
for(j=0;j<2;j++)
/Code
at least now i dont feel stupid :D
checking
int i, j;
for(i=0;i<4000;i++)
for(j=0;j<2;j++)
i got the same as eric
fvm i can get normal code tags to work just not the C code tags
Here you go..
C:
#include <xc.h>
unsigned char thingy;
void main(void)
   while(1)
here's the edit box before..
thanks mr Ian got it working :D
BTW why declare a variable then not use it! :stop::hilarious:
If we do code=asm, do we get the standard (?) Microchip colors? Or, should it be code=mpasm?
That is a nice enhancement.
John
not sure with ASM, yes it is a nice touch, i use programmers note pad II, so i like it as it looks the same on here as it does in that
I just did a quick and dirty test using preview, if that is an accurate way for a user to test. Neither code= asm nor code=mpasm work completely. Each gives colors, but they are messed up.
John
i just get a blank page with that link EM
