Canyouknott
i constructed this circuit in a PCB last night. Is it bad to have a few flying wires? It was pretty hard to avoid not using them
When you cascade 4510's to form an Up/Dn counter you can use the existing pins on the 4510's rather than AND gates.
Look at this image, I prefer the synchronous/parallel method of clocking.
Google: Cascading 4510 for more info.
E
BTW:
I assume the mode of operation is that you manually increment the counter to say 30 secs and then use the 555 output to decrement down to zero.???
How do you plan to stop the down count when it reaches 00.??
IF the maximum count is some fixed value between 1 and 99 you could use the Parallel Load to preset the counter to this value.
Do you mean the blue jumper wires? Yeah that is not good practice (but it will work). You should be able to fix that by using a double sided board. But... If you must use jumpers, or can't make double sided, then lay it out such that the jumpers do not run over IC's and are clean looking ie. use short vertical or horizontal, not zigzag. But all in all, your doing a good job, and I commend your work.i constructed this circuit in a PCB last night. Is it bad to have a few flying wires? It was pretty hard to avoid not using them
hi.I haven't learnt about Parallel Load? What is it![]()
Yes,Oh okay that sounds cool, is there any way I could modify my design so with the timer hits 'Zero,zero' then it stops?
No sorry but what are the data sheets for? Just information about the IC? or....hi,
Do you have the datasheet for the 4510 IC.?
hi,No sorry but what are the data sheets for? Just information about the IC? or....
I would, but my software sadly doesn't have that IC in it's libarysIt's much simpler to use this 4 digit counter and change the program. View attachment 93930
Yeah I figured that haha, but thats why I placed a variable resistor in the 555 timer circuit so the timer duration per pulse is longer. So if both players timers are the same therefore it doesn't technically need to be exactly in 1 second increments....A little about practical aspects of the device...
Maximum duration of the 99s is too short. Blitz game last at minimum 3 or 5 minutes, usually 15. It is possible to trim 555 timer, however players may lost some sense of real time.
Certainly it is far easier and cheaper to use any MCU, however this is great way to familiarize with logic gates and some other basic ICs.
What actually recommendations of the project are?
Electronics has sure hit home somewhere with me.. Considering this is my first 4 weeks of electronics in high school, I reckon I'm picking it up quite quickly but as you can obviosly see, I have alot of study left to go haha thanksMany kids are barely interested today for anything more than they are obligated. And use quite a lot google to find finished solution, make them practically useless and "google foo masters only" with diploma....
Well, bright feature certainly waiting for you...
Hi C,I have started to construct a circuit diagram of a chess clock
