I have got the mrs a ebike, it has a 36v 15ah battery pack.
I have a 1.8a 'intelligent' lead acid charger, only its not intelligent, it charges at 1.8a constant current, up to some voltage then switches to a taper charge, it has a uc3842 smps chip and a Lm358 op amp.
Open circuit voltage is 42v, which is correct for a 10s lipo, the question is would the lipos 'like' the taper charge, or woudl the charger not even get into that mode.
I got the pack as a load of panasonic cells welded together, and I of course got a Bms Pcb to go with it.
