Hi
We are required to power a load which itself is in parallel with a 72Ah Lithium Battery.
That is, we are tasked with making a power supply which will provide the 48V, at 240Amps to the load.
Normally, the battery provides power to the load by itself.
Since the load is 48V, 240Amps, does it not sound to you like the battery is under-spec’d at 72Ah?
Also, we have been told that when our power supply is powering the load, it must not put more than 90A into the battery. This seems odd. Howcome the battery cannot be charged with more than 90A, when it is said to supply 240Amps when powering the load?
