Probably varies depending on which sensor and what conditions... but not sure.
Can anyone give me some idea of how often a car/truck ECU/ECM samples various vehicle sensors.
At 6,000 RPM... that's 100 Rotations Per Second.
So if we sampled a sensor once per Rotation that would be 100 Samples Per Second
And if the ECU/ECM is monitoring 50 sensors at that rate...
then it would be taking samples 5,000 Per Second.
Or if we sampled the sensor 10 times per Rotation that would be 1,000 Samples Per Second.
then it would be taking 50,000 Samples Per Second.
But of course the sample rate may vary for various sensors... but I'm not sure...
So thanks for any help on researching the typical sample rate for various vehicle sensors.
- Mass Airflow Sensor
- Knock Sensor
- Manifold Absolute Pressure Sensor
- Oxygen/O2 Sensor
- NOx Sensor
- Engine Speed Sensor
- Throttle Position Sensor
- Crankshaft Position Sensor
- etc
