Quick advice on remote car starter?
Chucker2
Hi, 2003 2.5 Subaru Baja.
I got a car starter installed several years ago. It worked great for years. I stopped working a couple of years ago and I'm just getting around to trying to figure it out. It's a "Compustar" system.
The door lock/unlock function seems to work fine.
The car starter does not. It "connects" but it just causes (what I've always called) the "solenoid noise." - Not just the "click" but, many clicks in quick succession like happens with a low battery in the winter.
(*note - The car starts fine with the key - no issues).
I'm thinking it's just a bad wire connection somewhere. But does anyone have any idea which it might be and where to look for it?
Thank in advance for any thoughts!
I suggest that you try a new car battery. When the engine cranks, the battery voltage will always drop quite a lot. The electronic parts of the car that are needed to start the car will be made to keep working during cranking, but other stuff like the heating, aircon, and radio systems will often stop.
It sounds like the battery is getting old and during cranking the voltage is now just a bit too low for the remote starter. The OE stuff that responds to the key is managing to work to a lower voltage.
You could fit something to keep the voltage up during cranking. A lot of cars with start/stop systems have a second battery or a battery boost system so that the lights and radio can keep going during cranking.
However, for your car, it would take a lot of work and just fitting a replacement battery will be a lot easier.
If you can fit a larger battery, I suggest you do so. Even a small increase in size of battery can increase the life of the battery a lot. On one car I had, the original battery only lasted a couple of years. The replacement was about 20% longer and was the largest that would fit the battery tray and it lasted 5 years.
I'll be looking into this possibility tomorrow. Thanks!
Use a multimeter on the starter wire output from the Compustar when you trigger the remote start. You should see 12V for the duration of the crank attempt. If it pulses or drops, the relay/wire/fuse is weak
I would consider the current condition an anti-theft feature and not try to fix it. But then, maybe you live somewhere cars don't ever get stolen.
