can we use SCHOTTKY RECTIFIER instead of Rectifier diodes
nikhil arora
what are the advantages or disadvantages when i use
1N5822 or similar instead of 1N4001 or similar
Re: can we use SCHOTTKY RECTIFIER instead of Rectifier diode
There are some people who consider that they generate less noise?, but I can't comment on it being true or not?.
Personally I don't see any advantage, and I wouldn't consider using them for normal low frequency mains rectifiers.
Nikhil, is this for your smps project?
You'll deffinately want to use a schottky instead of a gp silicon rectifier ... I've tried it both ways, and the schottky works a lot better - it is almost always recommended that way in the datasheets as well.
If it's for a switch-mode supply you must not use a conventional rectifier, they are too slow and rapidly fail, however that wasn't what he asked? - unless he asked it very poorly?.
The downside is that Schottky does not have as sharp an IV curve. That is, higher currents make the voltage drop a bit higher. While it turns on at 0.3v, at high currents a Schottky can drop more voltage than a std rectifier, up to 1v or more. This is a somewhat inaccurate generalization however since it depends on the rated current of the Schottky. A current that drops 1v on a 1 amp Schottky might drop only 0.3v on a Schottky rated for 20 amps.
Schottky diodes DO have higher reverse leakage current, potentially much higher. The magnitude increases with the device's current rating, temperature, and reverse voltage. If it is a battery charger for example, this could drain battery current backwards into the transformer secondary winding in a significant way. It could drain the battery when the device has been turned off.
I have read some where that Schottky diode produce greater emi noise as they switch on and off rapidly.
