MrDEB
while researching multiplexing a matrix and using shift registers (control a 8x8 matrix with 12 port pins) I stumbled across the BCM method of dimming comparing with PWM and see the advantage of using BCM over PWM. Here is a code as an example of using BCM (no I did not write this code). Anyone use this method??
#include <avr/io.h>
#include <avr/interrupt.h>
unsigned char pwmValues[8] = {0x00,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //Exponential Approximation
volatile unsigned char bcmBuffer[8];
unsigned char BCMtracker = 0;
void calcBCM(void) {
for (unsigned char i=0; i<8; i++){ //Cycle though each bit of each pwmValues
unsigned char tempValue = 0;
for (unsigned char j=0; j<8; j++){
if (pwmValues[j] & (1<<i)) tempValue |= (1<<j); //Always set MSB because we're shifting right
bcmBuffer = tempValue;
int main(void)
//Setup IO
DDRD = 0xFF;
PORTD = 0xFF;
//Prewind the Binary Coded Modulation buffer
calcBCM();
//PORTD = bcmBuffer[7];
//while(1){}
//Setup Timer
cli(); //disable all interrupts
TCCR0A |= (1<<WGM01); //Use CTC mode
TCCR0B |= (1<<CS02); //Start timer with 256 prescaler
TIMSK0 |= (1<<OCIE0A); //Enable the compare A interrupt
OCR0A = 0x01; //Set to compare on first timer tick
sei(); //enable all interrupts
while(1)
//Loop Forever
ISR(TIMER0_COMPA_vect) //Compare match interrupt handler
//Update LEDs
PORTD = bcmBuffer[BCMtracker];
//Set interrupt for next BCM delay value
if (BCMtracker == 0) OCR0A = 0x01;
else OCR0A <<= 1;
//Increment the BCM tracking index
BCMtracker ++;
BCMtracker &= 7; //Flip back to zero when it gets to 8
#include <avr/io.h>
int main(void)
//Setup IO
DDRD = 0xFF;
PORTD = 0xFF;
calcBCM();
//while(1){}
//Setup Timer
while(1)
//Loop Forever
//Update LEDs
else OCR0A <<= 1;
BCMtracker ++;
