Battery-like Regulator?
Good call. Next time include layout, my crystal ball wasn't working. What no coax or stripline to antenna, with orthogonal orientation of antenna to diode input tracks?
It is all on the PCB, so no coax lead-outs.
The small square block to the right of the antenna is the audio output buffer.
oy.. just the right stub length for maximum interference.. try 30pf across differential inputs.
I think it might already have that, but I'll need to trace it and check. Good idea though.
Can you expand on what you mean about the ideal length for interference? I did think about attaching my own antenna made from a bit of wire to improve reception but I've not researched the requirements for a bluetooth antenna yet.
1/4 wavelength is an impedance transformer. and 1/2 wave is direct coupler.
You may need the right ferrite beads inserted before input. so with cap becomes LC filter
But suppression is the best cost balance between shielding and filter. We used both for 1GHz with tinned brass etched lids.
that is for you to discover.. too many details and possible solutions.
