rascupanamuha
Yep i have 15V, 2A power supply, so current cant be greater. But as you said, charging at 0.25C would last for a while. Maybe i should try to charge my 8Ah battery pack with 4A or even with 1C (8A), i will think about it.
Can i maybe use this current limiter? LT1084. I found it now, it is really simple and it can limit current to 3A, 5A or 7.5A. Or maybe not this one, but LM317 with 2W resistor (0.24ohm for 5A current limit)?
Or you think 2 transistors would be just fine? For transistor and LM317 version of current limiter i have everything but 2W resistors
This what you posted is VERY useful. Thank you
but again, i have some questions. http://www.zajic.cz/omezovac/omez sch.jpg
So T1 is that large transistor? Can i use P-mosfet there? And T2, R3, R4 and R5 are there only to light a led when a cell gets to 4.2V, is that true?
And in series with T1 i should put that shunt resistor?
Now to sum up, i have to put current limiter (something between 2A and 5A) to the my power supply input, and that schematic with TL431 to regulate that no cell has voltage higher than 4.20V.
Furthermore, if T2, R3, R4 and R5 are just for LEDs, i can eliminate them and use my uC to show me when my battery is full.
But what i dont get now is this: lets say my cells are 4.12V, 4.15V, 4.20V. They are charging in series, but TL431 senses that voltage on the first cell is 4.20V, so it turns T1 (or maybe mosfet) with series resistor (4.2V*0.5A=2W resistor), and then T1 dissipates 6.4W and resistor 2W, if current is 2A (but i want more). Is this correct? But how do i stop T1 and resistor from heating, and turn them off completely? But if i turn switch them off (with aditional mosfet maybe), than my 15V power supply would charge 2S battery? Would it be fine with current limiter?
Maybe i got it all right, i think i did, but if i didnt, please correct me
About this, i dont understand why there are 2 and not 3 shunt resistors. I understand that when all 3 are in parallel with each cell, that doesnt charge anything, but what is controlling them to shunt 3 cells?Also notice the 'hobbyking' charger only has two 2.2 ohm power resistors
